Introducción
Make sure to remove any memory cards and the battery before doing these steps.
Qué necesitas
Remove the Memory Card(s) from the camera
Remove the Battery from the Camera, and close the battery compartment cover
Remove the 2 screws beside the memory slots, then close the cover.
Note: make sure to remove the memory cards first!
Remove the 2 screws under the rubber grip part by peeling back the rubber grip
Try not to damage the double sided adhesive under the rubber.
Remove the 2 screws under the rubber pad marked in red.
Try not to damage the double-sided adhesive under the rubber.
Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
Lift out the assembly panel, it should come free without much force.
May open the panel to release it.
