Saltar al contenido principal
Nikon D40 Viewfinder Replacement
Qué necesitas
  1. Nikon D40 Viewfinder Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Viewfinder Replacement: paso 2, imagen 1 de 2 Nikon D40 Viewfinder Replacement: paso 2, imagen 2 de 2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Viewfinder Replacement: paso 3, imagen 1 de 1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Viewfinder Replacement: paso 4, imagen 1 de 1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Viewfinder Replacement, Viewfinder: paso 5, imagen 1 de 1
    • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
    • Be careful not to pull too hard on the ribbon cables.
  6. Nikon D40 Viewfinder Replacement: paso 6, imagen 1 de 1
    • Slowly push the upper body up until you see the frame of the viewfinder
    • Be careful while pulling the top camera body.
  7. Nikon D40 Viewfinder Replacement: paso 7, imagen 1 de 1
    • Use a spudger to keep the upper body separate from the printed circuit board.
    • Wiggle the plastic eyepiece out of the frame. This may require some force.
  8. Nikon D40 Viewfinder Replacement: paso 8, imagen 1 de 1
    • Remove the viewfinder with the plastic opening tool.
    • Do not push too hard while using the opening tool.
  9. Nikon D40 Viewfinder Replacement: paso 9, imagen 1 de 1
    • The viewfinder has been removed!
Conclusión
2 personas más completaron esta guía.
Amy Chen
Miembro Desde 01/23/14
193 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-19, Maness Winter 2014 Miembro de Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 3,310
