Saltar al contenido principal
Nikon D40 LCD Screen Replacement
Qué necesitas
  1. Nikon D40 LCD Screen Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 LCD Screen Replacement: paso 2, imagen 1 de 2 Nikon D40 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 LCD Screen Replacement: paso 4, imagen 1 de 1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
  6. Nikon D40 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Detach the ribbon cables on the LCD casing.
  7. Nikon D40 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the metal casing containing the LCD screen using the plastic opening tool.
    • Be sure to look at the picture to make sure you are removing the correct piece of metal. There should be no glue holding the correct piece to the frame.
  8. Nikon D40 LCD Screen Replacement: paso 8, imagen 1 de 1
    • You should now be able to remove the LCD screen. Replace it with a new screen.
Conclusión
4 personas más completaron esta guía.
Gerik Kubiak
Miembro Desde 01/21/14
327 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-19, Maness Winter 2014 Miembro de Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 32
Todo El Tiempo: 6,041
