Saltar al contenido principal
Nikon D3000 Motherboard Replacement
Qué necesitas
  1. Nikon D3000 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Nikon D3000 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
    • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
    • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
  2. Nikon D3000 Motherboard Replacement: paso 2, imagen 1 de 3 Nikon D3000 Motherboard Replacement: paso 2, imagen 2 de 3 Nikon D3000 Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
    • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
  3. Nikon D3000 Motherboard Replacement: paso 3, imagen 1 de 2 Nikon D3000 Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the following process for removing all ribbon connectors.
    • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
    • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
  4. Nikon D3000 Motherboard Replacement: paso 4, imagen 1 de 2 Nikon D3000 Motherboard Replacement: paso 4, imagen 2 de 2
    • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
    • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
    • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
    • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
    • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
  5. Nikon D3000 Motherboard Replacement: paso 5, imagen 1 de 2 Nikon D3000 Motherboard Replacement: paso 5, imagen 2 de 2
    • Lift the tabs and pull away the ribbon connectors shown .
    • Lift the motherboard and disconnect the grey connector from the bottom.
    • Disconnect and remove the motherboard.
Conclusión
3 personas más completaron esta guía.
Randall Heath
Miembro Desde 08/25/15
851 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 14-7, Meier Fall 2015 Miembro de USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 3,970
