Saltar al contenido principal
Nikon Coolpix S9700 Memory Card Replacement
  1. Nikon Coolpix S9700 Memory Card Replacement, Memory Card: paso 1, imagen 1 de 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: paso 1, imagen 2 de 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: paso 1, imagen 3 de 3
    • Power off the S9700 and situate it so that it is upside down.
    • Place your finger on the compartment door.
    • Gently push toward the front of the S9700.
    • The compartment door should spring open by itself.
  2. Nikon Coolpix S9700 Memory Card Replacement: paso 2, imagen 1 de 3 Nikon Coolpix S9700 Memory Card Replacement: paso 2, imagen 2 de 3 Nikon Coolpix S9700 Memory Card Replacement: paso 2, imagen 3 de 3
    • Locate the memory card. Be careful not to mistake it for the battery.
    • Push down on the memory card until it won't go down further. Don't push too hard to avoid damaging your camera
    • Release your finger and the card will pop up out of its compartment.
  3. Nikon Coolpix S9700 Memory Card Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S9700 Memory Card Replacement: paso 3, imagen 2 de 2
    • Grab your memory card with two fingers.
    • Gently pull up and your memory card will come out.
Conclusión
Matt Staubus
Miembro Desde 10/05/16
849 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 9-5, Lacy Fall 2016 Miembro de USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 509
