Saltar al contenido principal
Nikon Coolpix S9050 LCD Screen Replacement
Qué necesitas
  1. Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: paso 1, imagen 1 de 3 Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: paso 1, imagen 2 de 3 Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: paso 1, imagen 3 de 3
    • Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
    • Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
  2. Nikon Coolpix S9050 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the display frame and trim from the main body of the camera.
  3. Nikon Coolpix S9050 LCD Screen Replacement: paso 3, imagen 1 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 3, imagen 2 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Press down and pull the Menu Wheel/OK Button panel toward the screen.
    • This releases the panel from the slots.
  4. Nikon Coolpix S9050 LCD Screen Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Lift the black plastic tabs, which are securing the panel.
    • Gently pull the panel out to separate the display ribbon cable from the camera body.
  5. Nikon Coolpix S9050 LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the silver 3.2 mm Phillips #000 screw on the corner of the device to remove the screen.
  6. Nikon Coolpix S9050 LCD Screen Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S9050 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Gently remove pin connector using the spudger to disconnect the screen.
Conclusión
Kyle Gildner
Miembro Desde 11/05/19
199 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Stella Fall 2019 Miembro de IUPUI, Team S1-G5, Stella Fall 2019
IUPUI-STELLA-F19S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 266
