Saltar al contenido principal
Nikon Coolpix S8200 CCD Lens Replacement
Qué necesitas
  1. Nikon Coolpix S8200 CCD Lens Replacement, CCD Lens: paso 1, imagen 1 de 1
    • First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • Be careful not to remove any extra screws.
  2. Nikon Coolpix S8200 CCD Lens Replacement: paso 2, imagen 1 de 1
    • Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
  3. Nikon Coolpix S8200 CCD Lens Replacement: paso 3, imagen 1 de 1
    • Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Next gently remove the black strap indicated by the yellow circle on the image.
    • The black strap can easily snap back on for reassembly.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 5-3, Kish Spring 2015 Miembro de UMass Dartmouth, Team 5-3, Kish Spring 2015
UMASSD-KISH-S15S5G3
Miembros de 4
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 2,348
