Saltar al contenido principal
Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide
Qué necesitas
  1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: paso 1, imagen 1 de 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: paso 1, imagen 2 de 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 2, imagen 1 de 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 2, imagen 2 de 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Motherboard: paso 3, imagen 1 de 1
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 4, imagen 1 de 1
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 5, imagen 1 de 1
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 6, imagen 1 de 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 6, imagen 2 de 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 6, imagen 3 de 3
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 7, imagen 1 de 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 7, imagen 2 de 2
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 8, imagen 1 de 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: paso 8, imagen 2 de 2
    • Pull the motherboard off of the main body of the camera.
  9. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: paso 9, imagen 1 de 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: paso 9, imagen 2 de 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: paso 9, imagen 3 de 3
    • Use a plastic opening tool of your choice to loosen and pry up the zoom unit/shutter component.
    • Use your hands to manually lift the zoom unit/shutter component up and out of the main body of the camera.
Conclusión
Erik Knapton
Miembro Desde 01/30/18
222 Reputación
2 Guías creadas
Equipo
Baylor, Team S2-G6, Johnson Spring 2018 Miembro de Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 279
