Saltar al contenido principal
Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
Qué necesitas
  1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: paso 1, imagen 1 de 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: paso 1, imagen 2 de 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: paso 2, imagen 1 de 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: paso 2, imagen 2 de 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
Conclusión
2 personas más completaron esta guía.
Equipo
Baylor, Team S2-G6, Johnson Spring 2018 Miembro de Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
Miembros de 3
10 Guías creadas
1Guía Comentario
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
Brian Capouch - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 638
