Saltar al contenido principal
Nikon Coolpix S7000 Sticky Button Replacement
Qué necesitas
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: paso 2, imagen 1 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 2, imagen 2 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 2, imagen 3 de 3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S7000 Sticky Button Replacement: paso 3, imagen 2 de 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 4, imagen 3 de 3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: paso 5, imagen 1 de 1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: paso 6, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
Shannon Beane
Miembro Desde 01/10/17
324 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S2-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 2,472
