Saltar al contenido principal
Nikon Coolpix S7000 Shutter Button Replacement
Qué necesitas
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: paso 1, imagen 1 de 2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: paso 1, imagen 2 de 2
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S7000 Shutter Button Replacement: paso 2, imagen 2 de 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S7000 Shutter Button Replacement: paso 3, imagen 2 de 2
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S7000 Shutter Button Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S7000 Shutter Button Replacement: paso 4, imagen 3 de 3
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
Conclusión
Equipo
USF Tampa, Team S2-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
Miembros de 4
10 Guías creadas
Un comentario
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 778
