Saltar al contenido principal
Nikon Coolpix S70 Display Screen Replacement
Qué necesitas
  1. Nikon Coolpix S70 Display Screen Replacement, Display Screen: paso 1, imagen 1 de 2 Nikon Coolpix S70 Display Screen Replacement, Display Screen: paso 1, imagen 2 de 2
    • Power off the camera before beginning.
    • Remove the battery by sliding the latch located at the bottom of the camera.
  2. Nikon Coolpix S70 Display Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S70 Display Screen Replacement: paso 2, imagen 2 de 2
    • Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
  3. Nikon Coolpix S70 Display Screen Replacement: paso 3, imagen 1 de 3 Nikon Coolpix S70 Display Screen Replacement: paso 3, imagen 2 de 3 Nikon Coolpix S70 Display Screen Replacement: paso 3, imagen 3 de 3
    • Use a plastic opening tool to carefully separate the back panel of the camera.
    • Once loosened, use your fingers to manually separate the two panels.
  4. Nikon Coolpix S70 Display Screen Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S70 Display Screen Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S70 Display Screen Replacement: paso 4, imagen 3 de 3
    • Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
  5. Nikon Coolpix S70 Display Screen Replacement: paso 5, imagen 1 de 1
    • Carefully disconnect the orange flat ribbon cables from the latches.
  6. Nikon Coolpix S70 Display Screen Replacement: paso 6, imagen 1 de 3 Nikon Coolpix S70 Display Screen Replacement: paso 6, imagen 2 de 3 Nikon Coolpix S70 Display Screen Replacement: paso 6, imagen 3 de 3
    • Remove the screen from the case of the camera by carefully pushing on the back of the screen.
    • You may need to push with a little force to get the screen to loosen.
Conclusión
4 personas más completaron esta guía.
Equipo
Texas Tech, Team 22-2, Rauch Fall 2015 Miembro de Texas Tech, Team 22-2, Rauch Fall 2015
TTU-RAUCH-F15S22G2
3 Miembros
1 Guía escrita
Un comentario
my camera's lens show blury photos and when zooming id makes sound
Aliudin Saleh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,107
