Introducción
If you need to replace a damaged display with a new display of the Nikon Coolpix S6500 you can do it with the help of this guide. For this guide, you will need a Phillips #1 Screwdriver to remove the screws. Store the screws safely. Remove the case and display carefully. Before beginning, make sure to power off the camera completely and disconnect it from any external power source.
Qué necesitas
Casi Terminas!
Conclusión
