Saltar al contenido principal
Nikon Coolpix S6300 Display Replacement
Qué necesitas
  1. Nikon Coolpix S6300 Display Replacement, Battery: paso 1, imagen 1 de 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: paso 2, imagen 1 de 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: paso 3, imagen 1 de 3 Nikon Coolpix S6300 Display Replacement, Buttons: paso 3, imagen 2 de 3 Nikon Coolpix S6300 Display Replacement, Buttons: paso 3, imagen 3 de 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S6300 Display Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S6300 Display Replacement: paso 4, imagen 3 de 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: paso 6, imagen 1 de 1
    • Disconnect the connectors using a plastic spudger.
    • Be careful when removing the cables to prevent damaging the connectors.
  7. Nikon Coolpix S6300 Display Replacement: paso 7, imagen 1 de 1
    • You may now remove the internal panel of the buttons.
  8. Nikon Coolpix S6300 Display Replacement, Display: paso 8, imagen 1 de 1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
Conclusión
Hung
Miembro Desde 09/01/15
383 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-2, Remmell Fall 2015 Miembro de USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Miembros
10 Guías creadas
2 comentarios
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - Contestar
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 1,626
