Saltar al contenido principal
Nikon Coolpix S630 Shutter Button Replacement
Qué necesitas
  1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: paso 1, imagen 1 de 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Shutter Button Replacement, Battery: paso 2, imagen 1 de 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: paso 3, imagen 1 de 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: paso 4, imagen 1 de 1
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  5. Nikon Coolpix S630 Shutter Button Replacement: paso 5, imagen 1 de 1
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  6. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: paso 6, imagen 1 de 1
    • Place the front cover facing down so that you can easily see the shutter button.
  7. Nikon Coolpix S630 Shutter Button Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
Conclusión
Equipo
Cal Poly, Team 8-56, Johann Spring 2013 Miembro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
Miembros de 4
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 2,310
