Saltar al contenido principal
Nikon Coolpix S630 Back Cover Replacement
Qué necesitas
  1. Nikon Coolpix S630 Back Cover Replacement, Battery Compartment: paso 1, imagen 1 de 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Back Cover Replacement, Battery: paso 2, imagen 1 de 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Back Cover Replacement, Memory Card: paso 3, imagen 1 de 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: paso 4, imagen 1 de 3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: paso 4, imagen 2 de 3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: paso 4, imagen 3 de 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Back Cover Replacement: paso 5, imagen 1 de 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: paso 6, imagen 1 de 2 Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Conclusión
Anna Katrina
Miembro Desde 04/18/13
28 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-56, Johann Spring 2013 Miembro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
Miembros de 4
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 510
