Saltar al contenido principal
Nikon Coolpix S5300 Lens Replacement
Qué necesitas
  1. Nikon Coolpix S5300 Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 Lens Replacement: paso 2, imagen 1 de 1
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 Lens Replacement, Outer Casing: paso 3, imagen 1 de 3 Nikon Coolpix S5300 Lens Replacement, Outer Casing: paso 3, imagen 2 de 3 Nikon Coolpix S5300 Lens Replacement, Outer Casing: paso 3, imagen 3 de 3
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 Lens Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S5300 Lens Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S5300 Lens Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 Lens Replacement: paso 5, imagen 1 de 3 Nikon Coolpix S5300 Lens Replacement: paso 5, imagen 2 de 3 Nikon Coolpix S5300 Lens Replacement: paso 5, imagen 3 de 3
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 Lens Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S5300 Lens Replacement: paso 6, imagen 2 de 2
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 Lens Replacement: paso 7, imagen 1 de 2 Nikon Coolpix S5300 Lens Replacement: paso 7, imagen 2 de 2
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 Lens Replacement, Button Panel: paso 8, imagen 1 de 1
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 Lens Replacement: paso 9, imagen 1 de 2 Nikon Coolpix S5300 Lens Replacement: paso 9, imagen 2 de 2
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  10. Nikon Coolpix S5300 Lens Replacement, LCD Display Screen: paso 10, imagen 1 de 2 Nikon Coolpix S5300 Lens Replacement, LCD Display Screen: paso 10, imagen 2 de 2
    • Carefully remove the screen away from the silver plate.
    • Carefully fold the screen over exposing the latch for the ribbon cable.
  11. Nikon Coolpix S5300 Lens Replacement: paso 11, imagen 1 de 3 Nikon Coolpix S5300 Lens Replacement: paso 11, imagen 2 de 3 Nikon Coolpix S5300 Lens Replacement: paso 11, imagen 3 de 3
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  12. Nikon Coolpix S5300 Lens Replacement: paso 12, imagen 1 de 1
    • Once the ribbon cable is disconnected, remove the LCD screen.
  13. Nikon Coolpix S5300 Lens Replacement, Image Sensor: paso 13, imagen 1 de 2 Nikon Coolpix S5300 Lens Replacement, Image Sensor: paso 13, imagen 2 de 2
    • Using the phillips head screwdriver, remove the three 0.1mm screws on the metal plate.
    • Carefully remove metal plate from the camera.
  14. Nikon Coolpix S5300 Lens Replacement: paso 14, imagen 1 de 3 Nikon Coolpix S5300 Lens Replacement: paso 14, imagen 2 de 3 Nikon Coolpix S5300 Lens Replacement: paso 14, imagen 3 de 3
    • Use the plastic opening tool or your finger nail to carefully flip up the ribbon cable retaining flap.
    • Use the same screwdriver to remove the three 3mm screws that were revealed after removing the metal plate.
  15. Nikon Coolpix S5300 Lens Replacement: paso 15, imagen 1 de 1
    • Gently pull the ribbon cable to remove the image sensor.
  16. Nikon Coolpix S5300 Lens Replacement, Lens: paso 16, imagen 1 de 3 Nikon Coolpix S5300 Lens Replacement, Lens: paso 16, imagen 2 de 3 Nikon Coolpix S5300 Lens Replacement, Lens: paso 16, imagen 3 de 3
    • Be sure you are prying up on the black hinged retaining flap, not the connector itself.
    • Carefully push the lens towards you until it is almost removed from the chamber.
    • Remove the lens assembly from the camera.
Conclusión
Una persona más ha completado esta guía.
Riordan McCole
Miembro Desde 03/04/16
307 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 Miembro de UMass Dartmouth, Team 6-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 812
