Saltar al contenido principal
Nikon Coolpix S5200 Plastic Back Cover Replacement
Qué necesitas
  1. Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: paso 1, imagen 1 de 3 Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: paso 1, imagen 2 de 3 Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: paso 1, imagen 3 de 3
    • Locate the left side of the camera
  2. Nikon Coolpix S5200 Plastic Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the two 0.1 mm screws using a Phillips Head screwdriver in order to properly open the camera
  3. Nikon Coolpix S5200 Plastic Back Cover Replacement: paso 3, imagen 1 de 1
    • Carefully lift the plastic back cover away from the camera
    • Remove the plastic cover from the camera
  4. Nikon Coolpix S5200 Plastic Back Cover Replacement: paso 4, imagen 1 de 2 Nikon Coolpix S5200 Plastic Back Cover Replacement: paso 4, imagen 2 de 2
    • Carefully push the rubber button cover up and out of the plastic cover
    • The plastic cover has been properly removed and is ready to be replaced
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 354
