Saltar al contenido principal
Nikon Coolpix S5200 LCD Screen Replacement
Qué necesitas
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: paso 1, imagen 3 de 3
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: paso 7, imagen 1 de 2 Nikon Coolpix S5200 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Conclusión
Un comentario
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 26
Todo El Tiempo: 1,113
