Saltar al contenido principal
Nikon Coolpix S51c Back Cover Replacement
Qué necesitas
  1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Nikon Coolpix S51c Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Back Cover Replacement: paso 2, imagen 1 de 1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Back Cover Replacement: paso 3, imagen 1 de 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Back Cover Replacement: paso 4, imagen 1 de 1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Back Cover Replacement: paso 5, imagen 1 de 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Conclusión
Una persona más ha completado esta guía.
Ryan
Miembro Desde 04/12/11
155 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 18-24, Garner Spring 2011 Miembro de Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,298
