Introducción
If your screen breaks or is no longer responsive to touch, then you will need to replace it. The LCD screen itself has two wires attached that will need to be separated from the motherboard, and reinstalled with the new part.
Qué necesitas
Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
There are 2 on each side, and 4 on the bottom.
Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
Using precision tweezers, gently remove the ribbon cable running from LCD to the bottom side of the motherboard.
