Saltar al contenido principal
Nikon Coolpix S4100 External Casing Replacement
Qué necesitas
  1. Nikon Coolpix S4100 External Casing Replacement, External Casing: paso 1, imagen 1 de 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: paso 1, imagen 2 de 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: paso 1, imagen 3 de 3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 External Casing Replacement: paso 2, imagen 1 de 1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 External Casing Replacement: paso 3, imagen 1 de 1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 External Casing Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S4100 External Casing Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S4100 External Casing Replacement: paso 4, imagen 3 de 3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 External Casing Replacement: paso 5, imagen 1 de 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 External Casing Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S4100 External Casing Replacement: paso 6, imagen 2 de 2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 External Casing Replacement: paso 7, imagen 1 de 3 Nikon Coolpix S4100 External Casing Replacement: paso 7, imagen 2 de 3 Nikon Coolpix S4100 External Casing Replacement: paso 7, imagen 3 de 3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 External Casing Replacement: paso 8, imagen 1 de 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 External Casing Replacement: paso 9, imagen 1 de 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 External Casing Replacement: paso 10, imagen 1 de 1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 External Casing Replacement: paso 11, imagen 1 de 1
    • Remove the top shell casing.
Conclusión
2 personas más completaron esta guía.
Equipo
Baylor, Team 4-2, Williams Fall 2015 Miembro de Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 925
