Saltar al contenido principal
Nikon Coolpix S4000 Screen Replacement
Qué necesitas
  1. Nikon Coolpix S4000 Screen  Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Screen  Replacement: paso 2, imagen 1 de 1
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Screen  Replacement, Casing: paso 3, imagen 1 de 3 Nikon Coolpix S4000 Screen  Replacement, Casing: paso 3, imagen 2 de 3 Nikon Coolpix S4000 Screen  Replacement, Casing: paso 3, imagen 3 de 3
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Screen  Replacement: paso 4, imagen 1 de 2 Nikon Coolpix S4000 Screen  Replacement: paso 4, imagen 2 de 2
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Screen  Replacement: paso 5, imagen 1 de 3 Nikon Coolpix S4000 Screen  Replacement: paso 5, imagen 2 de 3 Nikon Coolpix S4000 Screen  Replacement: paso 5, imagen 3 de 3
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Screen  Replacement, Lens Casing: paso 6, imagen 1 de 1
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Screen  Replacement: paso 7, imagen 1 de 2 Nikon Coolpix S4000 Screen  Replacement: paso 7, imagen 2 de 2
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  8. Nikon Coolpix S4000 Screen  Replacement, Screen: paso 8, imagen 1 de 1
    • Remove the single 2mm Phillips #000 screw.
  9. Nikon Coolpix S4000 Screen  Replacement: paso 9, imagen 1 de 3 Nikon Coolpix S4000 Screen  Replacement: paso 9, imagen 2 de 3 Nikon Coolpix S4000 Screen  Replacement: paso 9, imagen 3 de 3
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  10. Nikon Coolpix S4000 Screen  Replacement: paso 10, imagen 1 de 2 Nikon Coolpix S4000 Screen  Replacement: paso 10, imagen 2 de 2
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 374
