Saltar al contenido principal
Nikon Coolpix S4000 Camera Light Replacement
Qué necesitas
  1. Nikon Coolpix S4000 Camera Light Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Camera Light Replacement: paso 2, imagen 1 de 1
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Camera Light Replacement, Casing: paso 3, imagen 1 de 3 Nikon Coolpix S4000 Camera Light Replacement, Casing: paso 3, imagen 2 de 3 Nikon Coolpix S4000 Camera Light Replacement, Casing: paso 3, imagen 3 de 3
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Camera Light Replacement: paso 4, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 4, imagen 2 de 2
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Camera Light Replacement: paso 5, imagen 1 de 3 Nikon Coolpix S4000 Camera Light Replacement: paso 5, imagen 2 de 3 Nikon Coolpix S4000 Camera Light Replacement: paso 5, imagen 3 de 3
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Camera Light Replacement, Lens Casing: paso 6, imagen 1 de 1
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Camera Light Replacement: paso 7, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 7, imagen 2 de 2
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  8. Nikon Coolpix S4000 Camera Light Replacement, Screen: paso 8, imagen 1 de 1
    • Remove the single 2mm Phillips #000 screw.
  9. Nikon Coolpix S4000 Camera Light Replacement: paso 9, imagen 1 de 3 Nikon Coolpix S4000 Camera Light Replacement: paso 9, imagen 2 de 3 Nikon Coolpix S4000 Camera Light Replacement: paso 9, imagen 3 de 3
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  10. Nikon Coolpix S4000 Camera Light Replacement: paso 10, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 10, imagen 2 de 2
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
  11. Nikon Coolpix S4000 Camera Light Replacement, Lens: paso 11, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement, Lens: paso 11, imagen 2 de 2
    • Remove the two 3mm Phillips #000 screws.
  12. Nikon Coolpix S4000 Camera Light Replacement: paso 12, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 12, imagen 2 de 2
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
  13. Nikon Coolpix S4000 Camera Light Replacement: paso 13, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 13, imagen 2 de 2
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
  14. Nikon Coolpix S4000 Camera Light Replacement: paso 14, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 14, imagen 2 de 2
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
  15. Nikon Coolpix S4000 Camera Light Replacement: paso 15, imagen 1 de 1
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
  16. Nikon Coolpix S4000 Camera Light Replacement, Camera Light: paso 16, imagen 1 de 1
    • Remove the 3mm black screw from top of the camera light.
  17. Nikon Coolpix S4000 Camera Light Replacement: paso 17, imagen 1 de 1
    • Pull the camera light away to detach it from the camera.
  18. Nikon Coolpix S4000 Camera Light Replacement: paso 18, imagen 1 de 2 Nikon Coolpix S4000 Camera Light Replacement: paso 18, imagen 2 de 2
    • Remove the connected wires from the camera light.
    • Solder the wires on to the connectors of the new camera light.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 270
