Saltar al contenido principal
Nikon Coolpix S33 Motherboard Replacement
Qué necesitas
  1. Nikon Coolpix S33 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Nikon Coolpix S33 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove battery before initiating this step to avoid the possibility of electric shock.
    • Remove all four T5 Torx screws from the exterior of the camera.
    • Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
  2. Nikon Coolpix S33 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the two screws located above the HDMI and USB logos that are inside the camera's battery compartment using a JIS000 screwdriver.
  3. Nikon Coolpix S33 Motherboard Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S33 Motherboard Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, gently remove the back cover from the camera.
  4. Nikon Coolpix S33 Motherboard Replacement, LCD: paso 4, imagen 1 de 1
    • Be sure to have followed the steps to remove the Back Cover of your camera before beginning to replace the LCD Screen. This guide will cover just the replacement of the LCD Screen.
    • Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
  5. Nikon Coolpix S33 Motherboard Replacement: paso 5, imagen 1 de 1
    • Before pulling the LCD Screen out of the camera, you will need to disconnect the ribbon connector that attaches the screen to the camera.
    • Gently pull the ribbon connector out of it's slot. You should be able to remove it without the need of any tools.
  6. Nikon Coolpix S33 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 Nikon Coolpix S33 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove all three 15'' Torx screws. Gently pry off the LCD holder using a plastic opening tool.
    • Peel off the connecting tape under the LCD holder to disconnect it completely.
  7. Nikon Coolpix S33 Motherboard Replacement: paso 7, imagen 1 de 1
    • Peel back black electrical tape and disconnect the ribbon connectors from the mother board.
    • Disconect the wires from the motherboard.
    • Take out the two 15'' Phillips screws, as shown in the image, using a Phillips screwdriver.
  8. Nikon Coolpix S33 Motherboard Replacement: paso 8, imagen 1 de 1
    • Gently pry off the motherboard using a plastic opening tool.
Conclusión
5 personas más completaron esta guía.
Maria Frias
Miembro Desde 02/18/16
564 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 16-3, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 2,342
