Saltar al contenido principal
Nikon Coolpix S33 Battery and SD Card Replacement
Qué necesitas
  1. Nikon Coolpix S33  Battery and SD Card Replacement, Battery and SD Card: paso 1, imagen 1 de 2 Nikon Coolpix S33  Battery and SD Card Replacement, Battery and SD Card: paso 1, imagen 2 de 2
    • Make sure that your camera is turned off before beginning any replacement of parts.
    • Flip the camera over to the Battery/SD Card compartment at the bottom right of your camera, located directly under the Coolpix logo.
    • This slot is for the camera's battery.
    • This slot is for the camera's SD card.
    • Open up the compartment of the camera as shown in the images.
    • No tools are necessary for this replacement.
    • Using your finger, push on the latch in the direction of the arrow to release the battery from the locking mechanism holding it in your camera.
    • Push down the SD card to release it from the locking mechanism in your camera.
    • Once the Battery and SD Card are loose, you can pull them out of their respective slots.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-3, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 88
Todo El Tiempo: 3,761
