Saltar al contenido principal
Nikon Coolpix S3100 Camera Lens Replacement
Qué necesitas
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 1 de 3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 2 de 3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 3 de 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S3100 Camera Lens Replacement: paso 2, imagen 2 de 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S3100 Camera Lens Replacement: paso 3, imagen 2 de 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: paso 5, imagen 1 de 1
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: paso 6, imagen 1 de 1
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: paso 7, imagen 1 de 1
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: paso 8, imagen 1 de 1
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: paso 9, imagen 1 de 1
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: paso 10, imagen 1 de 1
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: paso 11, imagen 1 de 1
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: paso 12, imagen 1 de 1
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: paso 13, imagen 1 de 1
    • The lens is now separated.
Conclusión
11 personas más completaron esta guía.
Jorge
Miembro Desde 03/11/15
1,170 Reputación
7 Guías creadas
Equipo
6 comentarios
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - Contestar
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - Contestar
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - Contestar
I have same issue it shutter half opens and doesnt open correctly
shailendra - Contestar
my LCD screen is stuck on white after after i did this :(
andrew welles - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 59
Todo El Tiempo: 4,272
