Saltar al contenido principal
Nikon Coolpix S3100 Camera Holder Replacement
Qué necesitas
  1. Nikon Coolpix S3100 Camera Holder Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 1 de 3 Nikon Coolpix S3100 Camera Holder Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 2 de 3 Nikon Coolpix S3100 Camera Holder Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 3 de 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Holder Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S3100 Camera Holder Replacement: paso 2, imagen 2 de 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Holder Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S3100 Camera Holder Replacement: paso 3, imagen 2 de 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Holder Replacement, Holder: paso 4, imagen 1 de 1
    • Remove 2-2.90mm using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Holder Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
Conclusión
Jorge
Miembro Desde 03/11/15
1,170 Reputación
7 Guías creadas
Equipo
Colorado Springs, Team 2-4, Panko Spring 2015 Miembro de Colorado Springs, Team 2-4, Panko Spring 2015
UCCS-PANKO-S15S2G4
Miembros de 2
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 473
