Saltar al contenido principal
Nikon Coolpix S3100 Camera Disassembly
Qué necesitas
  1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: paso 1, imagen 1 de 3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: paso 1, imagen 2 de 3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: paso 1, imagen 3 de 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Disassembly: paso 2, imagen 1 de 2 Nikon Coolpix S3100 Camera Disassembly: paso 2, imagen 2 de 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Disassembly: paso 3, imagen 1 de 2 Nikon Coolpix S3100 Camera Disassembly: paso 3, imagen 2 de 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: paso 4, imagen 1 de 2 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: paso 4, imagen 2 de 2
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the orange board to the right. (picture 2)
  5. Nikon Coolpix S3100 Camera Disassembly: paso 5, imagen 1 de 3 Nikon Coolpix S3100 Camera Disassembly: paso 5, imagen 2 de 3 Nikon Coolpix S3100 Camera Disassembly: paso 5, imagen 3 de 3
    • Lift screen up holding the corners.
    • Gently pull to the left to release from ZIF connector. (picture 2)
    • Gently pull the orange board to the right. (picture 3)
  6. Nikon Coolpix S3100 Camera Disassembly: paso 6, imagen 1 de 2 Nikon Coolpix S3100 Camera Disassembly: paso 6, imagen 2 de 2
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the shutter up. (picture 2)
  7. Nikon Coolpix S3100 Camera Disassembly: paso 7, imagen 1 de 2 Nikon Coolpix S3100 Camera Disassembly: paso 7, imagen 2 de 2
    • Lens is now separated from body.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  8. Nikon Coolpix S3100 Camera Disassembly: paso 8, imagen 1 de 3 Nikon Coolpix S3100 Camera Disassembly: paso 8, imagen 2 de 3 Nikon Coolpix S3100 Camera Disassembly: paso 8, imagen 3 de 3
    • Use a nylon or metal spudger to release the lens.
    • Repeat step 4 to the opposite side of the lens. (picture 2)
    • Lens is now separated from metal.
  9. Nikon Coolpix S3100 Camera Disassembly: paso 9, imagen 1 de 3 Nikon Coolpix S3100 Camera Disassembly: paso 9, imagen 2 de 3 Nikon Coolpix S3100 Camera Disassembly: paso 9, imagen 3 de 3
    • Once you have all the parts separated, start cleaning them with an air compressor bottle. (as shown)
    • Using the provided straw, start spraying the parts. (pictures 2 and 3)
Conclusión
2 personas más completaron esta guía.
Jorge
Miembro Desde 03/11/15
1,170 Reputación
7 Guías creadas
Equipo
Un comentario
accidentally touched the wires for the cap even though i read the warning, can confirm, not fun
zettabyte - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 62
Todo El Tiempo: 3,514
