Saltar al contenido principal
Nikon Coolpix S30 LCD Screen Replacement
Qué necesitas
  1. Nikon Coolpix S30 LCD Screen Replacement, Batteries: paso 1, imagen 1 de 2 Nikon Coolpix S30 LCD Screen Replacement, Batteries: paso 1, imagen 2 de 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. Nikon Coolpix S30 LCD Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S30 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. Nikon Coolpix S30 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the batteries by gently tipping the camera.
  4. Nikon Coolpix S30 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 1
    • FIRST: remove the batteries.
    • Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
  5. Nikon Coolpix S30 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
    • Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
  6. Nikon Coolpix S30 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Gently separate the back panel from the rest of the camera.
  7. Nikon Coolpix S30 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove screw connecting the top right of the screen to the mother board.
  8. Nikon Coolpix S30 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
  9. Nikon Coolpix S30 LCD Screen Replacement: paso 9, imagen 1 de 2 Nikon Coolpix S30 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Remove connected strip by flipping up the small off-white plastic strip with tweezers.
    • Gently pull out the strip from the motherboard.
  10. Nikon Coolpix S30 LCD Screen Replacement: paso 10, imagen 1 de 2 Nikon Coolpix S30 LCD Screen Replacement: paso 10, imagen 2 de 2
    • Remove screw that is now in the top right corner. This will detach the screen entirely.
Conclusión
Una persona más ha completado esta guía.
Cassie Hamm
Miembro Desde 01/21/15
207 Reputación
2 Guías creadas
Equipo
Penn State, Team 2-4, Kaschak Winter 2015 Miembro de Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 867
