Saltar al contenido principal
Nikon Coolpix S220 Battery and Memory Card Replacement
Qué necesitas
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: paso 1, imagen 1 de 1
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: paso 3, imagen 1 de 1
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
Conclusión
2 personas más completaron esta guía.
Shauna
Miembro Desde 04/05/11
798 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-32, Maness Spring 2011 Miembro de Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Miembros
10 Guías creadas
Un comentario
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 60
Todo El Tiempo: 19,285
