Saltar al contenido principal
Nikon Coolpix S210 Circuit Board Cover Replacement
Qué necesitas
  1. Nikon Coolpix S210 Circuit Board Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 Circuit Board Cover Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S210 Circuit Board Cover Replacement: paso 2, imagen 2 de 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 Circuit Board Cover Replacement, Back Case: paso 3, imagen 1 de 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 Circuit Board Cover Replacement: paso 4, imagen 1 de 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 Circuit Board Cover Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 Circuit Board Cover Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S210 Circuit Board Cover Replacement: paso 6, imagen 2 de 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 Circuit Board Cover Replacement, LCD screen: paso 7, imagen 1 de 3 Nikon Coolpix S210 Circuit Board Cover Replacement, LCD screen: paso 7, imagen 2 de 3 Nikon Coolpix S210 Circuit Board Cover Replacement, LCD screen: paso 7, imagen 3 de 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 Circuit Board Cover Replacement: paso 8, imagen 1 de 1
    • Gently remove the LCD screen.
  9. Nikon Coolpix S210 Circuit Board Cover Replacement, Circuit Board Cover: paso 9, imagen 1 de 1
    • After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • Unscrew the 2.5mm screw next to the wrist-strap mount.
  10. Nikon Coolpix S210 Circuit Board Cover Replacement: paso 10, imagen 1 de 2 Nikon Coolpix S210 Circuit Board Cover Replacement: paso 10, imagen 2 de 2
    • Position the camera with the lens facing down and the shutter button facing you.
    • Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
    • The ribbon is being held in place by a black latch.
    • Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
    • With the ribbon unlatched, the entire metal plate should now be detached.
Conclusión
Paul Doyle
Miembro Desde 01/20/11
504 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-17, Amido Winter 2011 Miembro de Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 1,969
