Saltar al contenido principal
Nikon Coolpix P530 Battery Replacement
Qué necesitas
  1. Nikon Coolpix P530 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: paso 2, imagen 1 de 3 Nikon Coolpix P530 Battery Replacement: paso 2, imagen 2 de 3 Nikon Coolpix P530 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: paso 3, imagen 1 de 3 Nikon Coolpix P530 Battery Replacement: paso 3, imagen 2 de 3 Nikon Coolpix P530 Battery Replacement: paso 3, imagen 3 de 3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: paso 4, imagen 1 de 2 Nikon Coolpix P530 Battery Replacement: paso 4, imagen 2 de 2
    • Gently remove the battery from the chamber.
Conclusión
3 personas más completaron esta guía.
3 comentarios
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Contestar
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Contestar
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 3,793
