Introducción
This guide will provide instructions on the process for replacing or removing the back cover of the camera. Removing the back cover of the camera allows for the internal components to be exposed for replacement.
Qué necesitas
Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
Identify the small notch below the camera flash where the body of the camera and the back cover join.
Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
Herramienta utilizada en este paso:Tweezers$4.99
Gently lift the back cover away from the camera body.
A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
Una persona más ha completado esta guía.
Un comentario
Hi Alan. Firstly - Great guide! Simple and clear, which for someone like myself is a necessity, lol!
Secondly - Is this how you would gain access to the menu, delete, and function buttons?
And last but certainly not least - Would you happen to know if this would (basically) be the same for a COOLPIX P520, by any chance? .
As you may've guessed, my P520 menu, delete and function buttons have suddenly stopped working, which makes 95% of my cameras functions and options unusable. After reading through your guide, I can see that the bodies for the two cameras are incredibly similar, so I thought you might be able to shed a little light on this for me. Thank you in advance! Toni
