Saltar al contenido principal
Nikon Coolpix P510 Lens Assembly Replacement
Qué necesitas
  1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: paso 1, imagen 1 de 2 Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: paso 1, imagen 2 de 2
    • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
    • On the thumb grip, remove the one 4mm PH00 Philips screw.
  2. Nikon Coolpix P510 Lens Assembly Replacement: paso 2, imagen 1 de 1
    • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
    • One of the screws are under the HDMI and A/V Out cover.
  3. Nikon Coolpix P510 Lens Assembly Replacement: paso 3, imagen 1 de 1
    • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
  4. Nikon Coolpix P510 Lens Assembly Replacement: paso 4, imagen 1 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 4, imagen 2 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 4, imagen 3 de 3
    • Open the flash and use a plastic opening tool to pop the tab under it as shown.
    • Now pull the casing apart.
    • The tripod attachment may fall out on its own, or you will need to pull it out.
  5. Nikon Coolpix P510 Lens Assembly Replacement: paso 5, imagen 1 de 2 Nikon Coolpix P510 Lens Assembly Replacement: paso 5, imagen 2 de 2
    • Unplug the two ribbon cables to completely detach the back.
  6. Nikon Coolpix P510 Lens Assembly Replacement: paso 6, imagen 1 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 6, imagen 2 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 6, imagen 3 de 3
    • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
    • Remove one 5mm PH00 Philips screw
    • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
    • With all the screws out, the metal plate should simply lift off.
  7. Nikon Coolpix P510 Lens Assembly Replacement: paso 7, imagen 1 de 2 Nikon Coolpix P510 Lens Assembly Replacement: paso 7, imagen 2 de 2
    • With the metal plate off, unplug this ribbon cable from the motherboard.
    • To remove the flat-topped connector, you simply lift it up to unplug it.
  8. Nikon Coolpix P510 Lens Assembly Replacement: paso 8, imagen 1 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 8, imagen 2 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 8, imagen 3 de 3
    • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
  9. Nikon Coolpix P510 Lens Assembly Replacement: paso 9, imagen 1 de 2 Nikon Coolpix P510 Lens Assembly Replacement: paso 9, imagen 2 de 2
    • With the support screws out, you can simply slide the assembly out of the casing.
  10. Nikon Coolpix P510 Lens Assembly Replacement: paso 10, imagen 1 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 10, imagen 2 de 3 Nikon Coolpix P510 Lens Assembly Replacement: paso 10, imagen 3 de 3
    • If you are moving on to take the lens casing off, you do not need to do this step.
    • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
Conclusión
9 personas más completaron esta guía.
Brian Hulsey
Miembro Desde 03/31/15
1,461 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 57
Todo El Tiempo: 3,741
