Saltar al contenido principal
Nikon Coolpix P510 LCD Replacement
Qué necesitas
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: paso 1, imagen 1 de 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: paso 2, imagen 1 de 2 Nikon Coolpix P510 LCD Replacement: paso 2, imagen 2 de 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: paso 3, imagen 1 de 2 Nikon Coolpix P510 LCD Replacement, LCD Screen Window: paso 3, imagen 2 de 2
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: paso 4, imagen 1 de 2 Nikon Coolpix P510 LCD Replacement: paso 4, imagen 2 de 2
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: paso 5, imagen 1 de 2 Nikon Coolpix P510 LCD Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
  6. Nikon Coolpix P510 LCD Replacement, LCD: paso 6, imagen 1 de 2 Nikon Coolpix P510 LCD Replacement, LCD: paso 6, imagen 2 de 2
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: paso 7, imagen 1 de 2 Nikon Coolpix P510 LCD Replacement: paso 7, imagen 2 de 2
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: paso 8, imagen 1 de 1
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
Conclusión
5 personas más completaron esta guía.
Brian Hulsey
Miembro Desde 03/31/15
1,461 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 48
Todo El Tiempo: 5,626
