Saltar al contenido principal
Nikon Coolpix P510 Battery Removal Replacement
Qué necesitas
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: paso 1, imagen 1 de 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: paso 2, imagen 1 de 2 Nikon Coolpix P510 Battery Removal Replacement: paso 2, imagen 2 de 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Conclusión
Brian Hulsey
Miembro Desde 03/31/15
1,461 Reputación
6 Guías creadas
Equipo
3 comentarios
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Contestar
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Contestar
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 4,172
