Saltar al contenido principal
Nikon Coolpix P4 Motherboard Replacement
Qué necesitas
  1. Nikon Coolpix P4 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • 'Click' the battery door over to the side.
  2. Nikon Coolpix P4 Motherboard Replacement: paso 2, imagen 1 de 1
    • Open the battery door. Inside is the memory card and the battery.
    • Click over the orange tab and take out the battery.
    • Close the battery lid by pushing it down and sliding it back.
  3. Nikon Coolpix P4 Motherboard Replacement, LCD Screen: paso 3, imagen 1 de 1
    • Remove the four screws located on bottom of camera. (.086in screws)
  4. Nikon Coolpix P4 Motherboard Replacement: paso 4, imagen 1 de 2 Nikon Coolpix P4 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the two screws, then remove the panel. (.113in screws)
  5. Nikon Coolpix P4 Motherboard Replacement: paso 5, imagen 1 de 3 Nikon Coolpix P4 Motherboard Replacement: paso 5, imagen 2 de 3 Nikon Coolpix P4 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove panel on right side (front view) by removing these two screws. (.196in screws)
    • Remove single screw set underneath panel. (0.083in screw)
  6. Nikon Coolpix P4 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
  7. Nikon Coolpix P4 Motherboard Replacement: paso 7, imagen 1 de 1
    • Gently pull off back cover
  8. Nikon Coolpix P4 Motherboard Replacement: paso 8, imagen 1 de 2 Nikon Coolpix P4 Motherboard Replacement: paso 8, imagen 2 de 2
    • Then remove the three screws on the A/V Out tab (left side). (.188in screws)
    • Remove tab.
  9. Nikon Coolpix P4 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
  10. Nikon Coolpix P4 Motherboard Replacement: paso 10, imagen 1 de 1
    • Flip up front panel.
    • There should be wires still attaching the panel to body. DO NOT TRY TO PULL OFF COMPLETELY
  11. Nikon Coolpix P4 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
  12. Nikon Coolpix P4 Motherboard Replacement: paso 12, imagen 1 de 1
    • Carefully pull orange LCD connector up and out of the port.
    • Be careful to pull vertically while pushing the black tab upwards
  13. Nikon Coolpix P4 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the screw below the LCD (.124in)
  14. Nikon Coolpix P4 Motherboard Replacement: paso 14, imagen 1 de 1
    • Carefully pull out the plug connecting the LCD to the motherboard.
  15. Nikon Coolpix P4 Motherboard Replacement: paso 15, imagen 1 de 1
    • You can now remove the LCD from the camera body.
    • Insert new LCD and reassemble using the steps in reverse order.
  16. Nikon Coolpix P4 Motherboard Replacement, Motherboard: paso 16, imagen 1 de 1
    • Remove the screw to the right of the flash.
    • Remove the screw to the right of the microphone on the bottom. (0.124in)
  17. Nikon Coolpix P4 Motherboard Replacement: paso 17, imagen 1 de 1
    • Remove the two screws on the right side of the camera. (0.115 in screws)
  18. Nikon Coolpix P4 Motherboard Replacement: paso 18, imagen 1 de 1
    • Remove the four bottom screws (0.116in [fat head]-center screw, 0.112in [skinny head]-other screws).
  19. Nikon Coolpix P4 Motherboard Replacement: paso 19, imagen 1 de 1
    • Remove the 7 screws from the back of the camera (0.111in screws).
  20. Nikon Coolpix P4 Motherboard Replacement: paso 20, imagen 1 de 1
    • Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the plug's base and pull it gently away from the camera.
  21. Nikon Coolpix P4 Motherboard Replacement: paso 21, imagen 1 de 1
    • Remove the right panel.
  22. Nikon Coolpix P4 Motherboard Replacement: paso 22, imagen 1 de 1
    • Remove the screw from the top of the camera (0.112in screws).
  23. Nikon Coolpix P4 Motherboard Replacement: paso 23, imagen 1 de 1
    • Remove the three screws from the motherboard (0.112in screws).
    • Detach the orange tab with the foam on top. It will click out of place.
  24. Nikon Coolpix P4 Motherboard Replacement: paso 24, imagen 1 de 1
    • Remove the motherboard by pulling it up and out of the port.
  25. Nikon Coolpix P4 Motherboard Replacement: paso 25, imagen 1 de 1
    • Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling the connector to the right and out of its port.
  26. Nikon Coolpix P4 Motherboard Replacement: paso 26, imagen 1 de 1
    • Remove the motherboard from the camera body.
    • Replace it with a new motherboard.
    • Follow the steps in reverse order to reassemble it.
Conclusión
Luke Baumann
Miembro Desde 04/13/11
128 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-5, Regan Spring 2011 Miembro de Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,436
