Introducción
In this guide we will take you through replacing a Nikon Coolpix P4 Flash Bulb.
If the flash is not working on your camera, then the flash bulb should be replaced.
Step 30 requires you to unsolder red and black wires. You can use this guide on how to solder and desolder connections.
After you replace it with a new flash bulb, follow these steps in reverse order to reassemble.
Qué necesitas
Remove the screw to the right of the flash.
Remove the screw to the right of the microphone on the bottom. (0.124in)
Remove the orange plug by carefully pulling it out. It snaps in and out of place.
Remove the tab connecting the flash to the motherboard by gently pulling the connector sideways out of its port, away from flash unit.
Unsolder red and black wires.
Remove the flash unit.
