Saltar al contenido principal
Nikon Coolpix P100 Viewfinder Replacement
Qué necesitas
  1. Nikon Coolpix P100 Viewfinder Replacement, Nikon Coolpix P100  Motherboard Access: paso 1, imagen 1 de 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Viewfinder Replacement: paso 2, imagen 1 de 3 Nikon Coolpix P100 Viewfinder Replacement: paso 2, imagen 2 de 3 Nikon Coolpix P100 Viewfinder Replacement: paso 2, imagen 3 de 3
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100 Viewfinder Replacement: paso 3, imagen 1 de 1
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100 Viewfinder Replacement: paso 4, imagen 1 de 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100 Viewfinder Replacement: paso 5, imagen 1 de 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Viewfinder Replacement: paso 6, imagen 1 de 2 Nikon Coolpix P100 Viewfinder Replacement: paso 6, imagen 2 de 2
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100 Viewfinder Replacement: paso 7, imagen 1 de 3 Nikon Coolpix P100 Viewfinder Replacement: paso 7, imagen 2 de 3 Nikon Coolpix P100 Viewfinder Replacement: paso 7, imagen 3 de 3
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100 Viewfinder Replacement: paso 8, imagen 1 de 1
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100 Viewfinder Replacement: paso 9, imagen 1 de 1
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100 Viewfinder Replacement: paso 10, imagen 1 de 1
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100 Viewfinder Replacement: paso 11, imagen 1 de 1
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100 Viewfinder Replacement: paso 12, imagen 1 de 1
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100 Viewfinder Replacement: paso 13, imagen 1 de 1
    • Now you have access to the camera's motherboard
  14. Nikon Coolpix P100 Viewfinder Replacement, Viewfinder: paso 14, imagen 1 de 1
    • Remove the screw that is located on the left of the view finder.
  15. Nikon Coolpix P100 Viewfinder Replacement: paso 15, imagen 1 de 1
    • Carefully detach the two ribbon cables and detach the viewfinder.
Conclusión
3 personas más completaron esta guía.
Nghiem Ngo
Miembro Desde 01/15/15
330 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Tanski Winter 2015 Miembro de USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
Miembros de 3
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 1,175
