Saltar al contenido principal
Nikon Coolpix P100 Display Screen Replacement
Qué necesitas
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: paso 1, imagen 1 de 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: paso 1, imagen 2 de 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: paso 1, imagen 3 de 3
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix P100 Display Screen Replacement: paso 2, imagen 2 de 2
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: paso 3, imagen 1 de 1
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: paso 4, imagen 1 de 1
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: paso 5, imagen 1 de 3 Nikon Coolpix P100 Display Screen Replacement: paso 5, imagen 2 de 3 Nikon Coolpix P100 Display Screen Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: paso 6, imagen 1 de 3 Nikon Coolpix P100 Display Screen Replacement: paso 6, imagen 2 de 3 Nikon Coolpix P100 Display Screen Replacement: paso 6, imagen 3 de 3
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: paso 7, imagen 1 de 1
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: paso 8, imagen 1 de 1
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: paso 9, imagen 1 de 2 Nikon Coolpix P100 Display Screen Replacement: paso 9, imagen 2 de 2
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: paso 10, imagen 1 de 2 Nikon Coolpix P100 Display Screen Replacement: paso 10, imagen 2 de 2
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
Conclusión
5 personas más completaron esta guía.
Rikki Brown
Miembro Desde 01/09/15
267 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Tanski Winter 2015 Miembro de USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Miembros
8 Guías creadas
3 comentarios
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - Contestar
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - Contestar
I can't reconnect the connector on the step 10. Can you help me?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 43
Todo El Tiempo: 2,726
