Saltar al contenido principal
Nikon Coolpix P100 Back Buttons Replacement
Qué necesitas
  1. Nikon Coolpix P100 Back Buttons Replacement, Back Buttons: paso 1, imagen 1 de 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Back Buttons Replacement: paso 2, imagen 1 de 3 Nikon Coolpix P100 Back Buttons Replacement: paso 2, imagen 2 de 3 Nikon Coolpix P100 Back Buttons Replacement: paso 2, imagen 3 de 3
    • On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
  3. Nikon Coolpix P100 Back Buttons Replacement: paso 3, imagen 1 de 1
    • On the right side of the camera, remove the first visible screw.
  4. Nikon Coolpix P100 Back Buttons Replacement: paso 4, imagen 1 de 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw.
  5. Nikon Coolpix P100 Back Buttons Replacement: paso 5, imagen 1 de 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Back Buttons Replacement: paso 6, imagen 1 de 2 Nikon Coolpix P100 Back Buttons Replacement: paso 6, imagen 2 de 2
    • Remove the two screws hidden underneath the display panel.
  7. Nikon Coolpix P100 Back Buttons Replacement: paso 7, imagen 1 de 3 Nikon Coolpix P100 Back Buttons Replacement: paso 7, imagen 2 de 3 Nikon Coolpix P100 Back Buttons Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to gently loosen up the sides of the camera.
  8. Nikon Coolpix P100 Back Buttons Replacement: paso 8, imagen 1 de 2 Nikon Coolpix P100 Back Buttons Replacement: paso 8, imagen 2 de 2
    • Carefully open the camera.
    • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
  9. Nikon Coolpix P100 Back Buttons Replacement: paso 9, imagen 1 de 2 Nikon Coolpix P100 Back Buttons Replacement: paso 9, imagen 2 de 2
    • This is the cover that houses the back buttons of the camera. Turn it around.
  10. Nikon Coolpix P100 Back Buttons Replacement: paso 10, imagen 1 de 1
    • Remove the six indicated screws.
  11. Nikon Coolpix P100 Back Buttons Replacement: paso 11, imagen 1 de 2 Nikon Coolpix P100 Back Buttons Replacement: paso 11, imagen 2 de 2
    • Use a plastic opening tool to lift the metal plate and set it aside.
  12. Nikon Coolpix P100 Back Buttons Replacement: paso 12, imagen 1 de 3 Nikon Coolpix P100 Back Buttons Replacement: paso 12, imagen 2 de 3 Nikon Coolpix P100 Back Buttons Replacement: paso 12, imagen 3 de 3
    • Turn the cover around and push against the buttons.
  13. Nikon Coolpix P100 Back Buttons Replacement: paso 13, imagen 1 de 1
    • Now you have partial access to one set of buttons.
  14. Nikon Coolpix P100 Back Buttons Replacement: paso 14, imagen 1 de 1
    • Find the last set of removal buttons on the bottom left.
  15. Nikon Coolpix P100 Back Buttons Replacement: paso 15, imagen 1 de 1
    • Remove the screw.
  16. Nikon Coolpix P100 Back Buttons Replacement: paso 16, imagen 1 de 2 Nikon Coolpix P100 Back Buttons Replacement: paso 16, imagen 2 de 2
    • Use a plastic opening tool to remove the button.
Conclusión
Nghiem Ngo
Miembro Desde 01/15/15
330 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Tanski Winter 2015 Miembro de USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 813
