Saltar al contenido principal
Nikon Coolpix L840 Motherboard Replacement
Qué necesitas
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: paso 2, imagen 1 de 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: paso 3, imagen 1 de 2 Nikon Coolpix L840 Motherboard Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 1-11, Maness Spring 2016 Miembro de Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Miembros
10 Guías creadas
2 comentarios
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - Contestar
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 2,175
