Saltar al contenido principal
Nikon Coolpix L830 LCD Monitor Replacement
Qué necesitas
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: paso 1, imagen 1 de 1
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
  2. Nikon Coolpix L830 LCD Monitor Replacement: paso 2, imagen 1 de 1
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
  3. Nikon Coolpix L830 LCD Monitor Replacement: paso 3, imagen 1 de 2 Nikon Coolpix L830 LCD Monitor Replacement: paso 3, imagen 2 de 2
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
  4. Nikon Coolpix L830 LCD Monitor Replacement: paso 4, imagen 1 de 1
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
  5. Nikon Coolpix L830 LCD Monitor Replacement: paso 5, imagen 1 de 2 Nikon Coolpix L830 LCD Monitor Replacement: paso 5, imagen 2 de 2
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
  6. Nikon Coolpix L830 LCD Monitor Replacement: paso 6, imagen 1 de 1
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
  7. Nikon Coolpix L830 LCD Monitor Replacement: paso 7, imagen 1 de 1
    • Gently remove the old, damaged LCD monitor.
Conclusión
Una persona más ha completado esta guía.
Blake Johnson
Miembro Desde 10/28/16
347 Reputación
2 Guías creadas
Equipo
Baylor, Team 4-4, Williams Fall 2016 Miembro de Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 Miembros
10 Guías creadas
Un comentario
I cant remove two of the screws. Help
jo Hogan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 2,568
