Saltar al contenido principal
Nikon Coolpix L820 LCD Replacement
Qué necesitas
  1. Nikon Coolpix L820 LCD Replacement, Settings Buttons: paso 1, imagen 1 de 3 Nikon Coolpix L820 LCD Replacement, Settings Buttons: paso 1, imagen 2 de 3 Nikon Coolpix L820 LCD Replacement, Settings Buttons: paso 1, imagen 3 de 3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
  2. Nikon Coolpix L820 LCD Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L820 LCD Replacement: paso 2, imagen 2 de 2
    • Next, remove the screw held on top of the camera above the Nikon logo.
    • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
  3. Nikon Coolpix L820 LCD Replacement: paso 3, imagen 1 de 3 Nikon Coolpix L820 LCD Replacement: paso 3, imagen 2 de 3 Nikon Coolpix L820 LCD Replacement: paso 3, imagen 3 de 3
    • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
    • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
  4. Nikon Coolpix L820 LCD Replacement, LCD screen: paso 4, imagen 1 de 3 Nikon Coolpix L820 LCD Replacement, LCD screen: paso 4, imagen 2 de 3 Nikon Coolpix L820 LCD Replacement, LCD screen: paso 4, imagen 3 de 3
    • Remove the front casing around the LCD screen from the camera.
    • Avoid putting pressure or moving the exposed wires. This can damage them and cause lasting issue to the camera.
  5. Nikon Coolpix L820 LCD Replacement: paso 5, imagen 1 de 3 Nikon Coolpix L820 LCD Replacement: paso 5, imagen 2 de 3 Nikon Coolpix L820 LCD Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Using the tweezers shown in the materials list, lift the hinges connecting the two ribbon wires to the camera. The wires will unlatch from the device.
  6. Nikon Coolpix L820 LCD Replacement: paso 6, imagen 1 de 2 Nikon Coolpix L820 LCD Replacement: paso 6, imagen 2 de 2
    • Once the ribbon wires are disconnected, remove the LCD screen from the camera.
    • Safely store the LCD for reinstallation.
Conclusión
2 personas más completaron esta guía.
Lucas Otto
Miembro Desde 03/23/15
107 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-4, Miles Spring 2015 Miembro de UMass Dartmouth, Team 1-4, Miles Spring 2015
UMASSD-MILES-S15S1G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 2,451
