Saltar al contenido principal
Nikon Coolpix L810 LCD Replacement
Qué necesitas
  1. Nikon Coolpix L810 LCD Replacement, LCD: paso 1, imagen 1 de 2 Nikon Coolpix L810 LCD Replacement, LCD: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 LCD Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L810 LCD Replacement: paso 2, imagen 2 de 2
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 LCD Replacement: paso 3, imagen 1 de 2 Nikon Coolpix L810 LCD Replacement: paso 3, imagen 2 de 2
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 LCD Replacement: paso 4, imagen 1 de 1
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 LCD Replacement: paso 5, imagen 1 de 2 Nikon Coolpix L810 LCD Replacement: paso 5, imagen 2 de 2
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 LCD Replacement: paso 6, imagen 1 de 3 Nikon Coolpix L810 LCD Replacement: paso 6, imagen 2 de 3 Nikon Coolpix L810 LCD Replacement: paso 6, imagen 3 de 3
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 LCD Replacement: paso 7, imagen 1 de 2 Nikon Coolpix L810 LCD Replacement: paso 7, imagen 2 de 2
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
Conclusión
4 personas más completaron esta guía.
Emilio Mena
Miembro Desde 01/14/15
776 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team 3-1, Rose Winter 2015 Miembro de UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
4 Miembros
8 Guías creadas
2 comentarios
I love ifixit instructions so much more than youtube. These are so easy and straightfoward and I love how screw sizes are carefully specified.
Susan - Contestar
Congratulations! Perfect lesson !
I need HELP presentation abowt desassembler / remove motherboard and other parts to repair the lenz move mechanism. Unfortunately NIKON left Brazil and the resident Suport tecnician besides not being good, stay in quarentine (corona virus)! Special Thanks for you help! Best regards
ramos.eng - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 2,794
