Saltar al contenido principal
Nikon Coolpix L610 Control Panel Replacement
Qué necesitas
  1. Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: paso 1, imagen 1 de 2 Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: paso 1, imagen 2 de 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Control Panel Replacement: paso 2, imagen 1 de 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Control Panel Replacement: paso 3, imagen 1 de 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Control Panel Replacement: paso 4, imagen 1 de 3 Nikon Coolpix L610 Control Panel Replacement: paso 4, imagen 2 de 3 Nikon Coolpix L610 Control Panel Replacement: paso 4, imagen 3 de 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Control Panel Replacement, Control Panel: paso 5, imagen 1 de 3 Nikon Coolpix L610 Control Panel Replacement, Control Panel: paso 5, imagen 2 de 3 Nikon Coolpix L610 Control Panel Replacement, Control Panel: paso 5, imagen 3 de 3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Control Panel Replacement: paso 6, imagen 1 de 1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
Conclusión
Jeremy
Miembro Desde 01/21/15
982 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 9-4, Brown Winter 2015 Miembro de USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 486
