Saltar al contenido principal
Nikon Coolpix L610 Battery and Memory Card Replacement
  1. Nikon Coolpix L610 Battery and Memory Card Replacement, Battery and Memory Card: paso 1, imagen 1 de 1
    • The batteries are located on the bottom of the device on the right hand side. To open the compartment press the button in and slide it towards you and pull the door open.
  2. Nikon Coolpix L610 Battery and Memory Card Replacement: paso 2, imagen 1 de 1
    • The memory card is located next to the batteries. To remove the memory card press it in and it should pop out.
Conclusión
Una persona más ha completado esta guía.
Jeremy
Miembro Desde 01/21/15
1,027 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 9-4, Brown Winter 2015 Miembro de USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Miembros
12 Guías creadas
Un comentario
I need help - my Coolpix L610 battery door will not close and lock.
gmurphree1@aol.com - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 25
Todo El Tiempo: 2,177
