Saltar al contenido principal
Nikon Coolpix L340 Buttons Replacement
Qué necesitas
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: paso 1, imagen 1 de 1
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: paso 4, imagen 1 de 1
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: paso 5, imagen 1 de 1
    • Push buttons out of the back of the cover.
Conclusión
Robert Estrella
Miembro Desde 03/04/16
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,186
