Saltar al contenido principal
Nikon Coolpix L330 LCD Screen Replacement
Qué necesitas
  1. Nikon Coolpix L330 LCD Screen Replacement, Back Housing: paso 1, imagen 1 de 3 Nikon Coolpix L330 LCD Screen Replacement, Back Housing: paso 1, imagen 2 de 3 Nikon Coolpix L330 LCD Screen Replacement, Back Housing: paso 1, imagen 3 de 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 LCD Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L330 LCD Screen Replacement: paso 2, imagen 2 de 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
  3. Nikon Coolpix L330 LCD Screen Replacement, LCD Screen: paso 3, imagen 1 de 2 Nikon Coolpix L330 LCD Screen Replacement, LCD Screen: paso 3, imagen 2 de 2
    • Insert the tips of your fingers into the space between the screen and back-plate.
    • Gently lift the screen up and out of the frame.
    • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
  4. Nikon Coolpix L330 LCD Screen Replacement: paso 4, imagen 1 de 2 Nikon Coolpix L330 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Tilt the screen so that the display cable forms a hinge with the backplate.
    • Rotate the display 180 degrees so that it faces you.
  5. Nikon Coolpix L330 LCD Screen Replacement: paso 5, imagen 1 de 3 Nikon Coolpix L330 LCD Screen Replacement: paso 5, imagen 2 de 3 Nikon Coolpix L330 LCD Screen Replacement: paso 5, imagen 3 de 3
    • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
    • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
    • Slide the display cable out of the connector.
    • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
Conclusión
5 personas más completaron esta guía.
Rajeev
Miembro Desde 02/09/16
596 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 2-10, Cagle Spring 2016 Miembro de USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Miembros
14 Guías creadas
Un comentario
Thank you, saved me money and time
Mihai Alexandru Fustos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 1,810
